Here is the 264 cam Bogie was speaking of.
www.compcams.com
It will make better power than stock.
Or this one.
www.compcams.com
This one will have a choppy idle, and I have used it in a pretty much stock L31 and it ran really, really well.
Pushed my 4000 pound truck down the 1/4 in 13.5 seconds.
Since you are changing the springs, these could both be an option.
The bigger cam will be close with beehives.
And for what it's worth, I used stock rockers and pushrods with mine.
Again, Bogie is more familiar with exactly what needs to be done, but from what I gather you can achieve this with beehives. And he really has had good results with the 264. The GM Hotcam is always any option too. I think that 276 grind is very similar.
I'm just thinking in the future, when your car is together. I don't want you to say "I wish it has a little more power, I should have put a cam in it while it was apart..."
COMP Cams XR264HR Dyno Results
Dyno Results for Chevrolet 350 Small Block XR264HR-10
Or this one.
COMP Cams XR276HR Dyno Results
Dyno Results for Chevrolet 350 Small Block XR276HR Camshaft
