Everything will swap right in.
IIRC the bronco has a split front axle and the 77 F250 has a straight axle. So the oil pans, oil pickups and headers may be different for each application, but if they are, they will swap between motors with no problem.
Your accessory drives may be different also.
The 351m and 400 are virtually identical as far as bolt patterns, engine dimensions, etc. The only diff is stroke and pistons as far as I know.
Hope this helps,
Mikey
Hope this helps,
Mikey
