i got a 1981 trans am with a 355 afr 195 eliminator heads a crane energizer 286 cam with correct crane valve springs, 1.6 roller rockers, rpm intake, holley 770, hedman 1 3/4 headers, 3500 stall and 4.11 posi rear end my car will rev up fine in nuetral or park but when in gear it will only pull to 4500 and it will pop/misfire a little and seems like theres a rev limiter at 4500, my timing is set at 15 degrees at idle and 37 at 3000 rpm, i have a stock replacement accel distributor maybe it doesnt have enough power to make spark up there??
