A friend bought old chevy drag truck with 355. Man the rocker arms are loud at idle. He be-leaves there's hdy roller lifters in the motor. I adjusted the valves 3 times. O lash to 1/2 to 3/4 turns the valves are still loud. So I pulled the rocker arms and found - Rocker arms rubbing on the retaining rings and springs. The springs are single to, are not double or triple springs like on my motors. Push rod size 7.200. "O" I change the oil there was shavings in the oil. I don't when the motor was built. "O" to when the motor is running along with the rocker arms being loud I could here tap in the motor. What you guys think would cause this.
