pasadenahotrod said:
This swap is one of the oldest and easiest modifications ever!....The "bolt-in" master cylinder bracket and pedal assembly is from a 1939 Ford car or pickup ONLY. These are almost impossible to find so I did not mention it 'til last figuring you did want to drive your 37 not just look for rare parts.
Bleed 'em and adjust 'em and drive!!
thanks this is great info and just what i was hoping for, yes i do want to reuse those big wheels they are cool looking... fortunately i have two sets of everything, backing plates, whl cylinders,drums etc, including the 39 pedal assembly with the mstr cyl attached, this is courtesy of a friend who had a 36 and never got around to installing the parts so i bought his left over parts.....out of curiosity what would be a fair price to ask for selling the 39 pedal assembly/MSTR cyl, 4 whl cyls and the 4 extra backing plates?
let me ask you a couple more questions....
1.) also in looking at the rear backing plates it seems that i have two slightly different sets ....one set has the two brake shoe anchor pins that look they can adjust the brakes , but the other pair have riveted nipples in lieu of this, where the lower brake shoes attach?
why is there a difference?
2.) it looks to me that the set i will be using has adjusting points at the bottom with the anchor pins and then again with a concentric on each side that turns against the brake shoes? is this correct
3.) also the parts i bought came with another e-brake assembly...do i just reuse my existing e-brake handle and need to use different cables from the 39'? am i correct in stating that the 37 e-brake cables are not compatible with the 39 hydraulic brakes?
4.) do you know of a bolt up dual mstr cylinder that i can use with the 39 clutch/brake pedal assembly?
5.) do i need to pull the rear axle to put on the rear backing plates?
thanks for your help i appreciate it, Bob
