Thanks for the advice. Sorry. I don't understand what you mean by "filling the ends with sand" to allow for different angle bends. Can you clarify please? Thanks.
Filling pipes with oven dried "play sand" (after capping one end) and compressing it as you fill it before crushing/welding the other end is a old methoud of bending exhaust and steel tubing(not recommended for roll cages) .
The harder the material the more heat you need.
With copper tubing I have bent 2" by hand around a tree/log the radius I want. A bit of heat will help. But if you need 30" of tubing then bending 4' pipe around a tree or with one end held down and lifting the other against a log will allow for you to use simple leverage to bend copper easily.
You can do 15 or 30 degree bends with out to much concern. 45 and 60 I use a bit of heat with. Anything above 60 I simply use a "middle" section of rubber and run straight tubing.
So lets say you have a PS facing water pump outlet. You run a xx degree turn of rubber which also reduces the pipe diamiter using a 90's truck hose. To the tube then you bend to xx degrees or use another section of xx degree rubber in the middle of the tube before having another section of xx degree rubber going into the radiatior.
Flexible or not. Gates "green stripe" coolant hoses are highly recommended. They are a bit more upfront. But they are worth it to keep your engine cool.
