I bought a 69 chevy half ton from a friend of mine who had it sitting for about the last 6 years in that period it had only been driven a few times
The engine was built about 40 000 kms before that It fires right up and has 50psi of oil pressure at idle (after I changed it that is)
Is there anything I should do to this motor I was thinking of putting a new cam and lifters and valve springs in it and maybe replacing all the gaskets (so I dont have to worry about leaks and so I can check the heads and such)
This is what it has on it right now
041 heads
Carter 635 cfm performance series carb
Performer Manifold (its odd the where it says performer is at the back of the engine and its written facing the front)
Unsure of the cam specs
Anyways I have a Performer Rpm manifold I might slap on it but I wont be revving this thing high anyways is it worth sticking it on
and
The transmisson was also rebuilt and has less then 8000 kms on it its a Th400 and it has a higher stall converter and a shift kit (I am unsure of how high the stall is but when in drive this thing barely moves if at all at idle)
Is there any thing I should do to it besides change the fluid
I have never bought a Truck that has been sitting along time where the motor and tranny were actually good and usable.
041 heads
and
