1 - 12 of 12 Posts
My 400 in my 1979 1/2 ton Chev is in need of work. Basically everything except the bottom end. So i'm thinking of building a 383. What will I need for a good medium range engine. Comp. ratio? Heads? Pistons? Intake? Cam ect.. I want to do it right. But I don't konw anyone who has built one.
This is pretty much a very generic, vague question. Its YOUR engine and YOUR truck, build it how you want it to be. Edelbrock has a lot of nice parts to start with.
Buy a Chevy over the counter crate motor (See you local chevy dealer). Saves time, money and busted knuckles. These engines are really nice.
Why not use what you have? Rebuild your 400, install 350(5.7") rods, Edelbrock performer cam and intake, or similar. Keep the compression down, around 9.0 to 1, unless you use aluminum heads or can afford expensive gas. You will need to check for rod to cam lobe clearance. Your machine shop will know how to do this.
[ April 10, 2002: Message edited by: trophy ]</p>
Medium stroker bore 30 over flat top pistons hypertech 350 block 4 bolt main preferably you got to notch the block bottom of cylinders for clearance rod bolts also MUST be ground for cam clearance have crank assembly balanced they should do the grinding for you tell them what your doing you'll be alright with stock crank my opinion cam 470 lift 68 to 72cc heads valve size your pick dual plane intake 600 to 650 carb should get what your looking for should set you back about 1600$$
Try checking with local parts stores, performance shops, and performance parts companies. Most of them have a 383 kit for all sorts of power ranges and prices. All you would need is a 350 block bored .030 over.
If you have a SBC 400 and want a medium performance motor, I would just rebuild what you have. Your motor has good torque and has more upside potential than the 383. It would also be cheaper because you won't have to buy a block. People like me build 383's because we can't find a 400 block. The 383 will feel a lot like the 400, they have similar torque.
But, I will answer your question. Go to <a href="http://www.speedomotive.com" target="_blank">www.speedomotive.com</a> and look them over. They sell reasonably price kits for 383 builds and give you good assistance with questions etc. Or, you can save money by using the crank from your 400. You can build a 400hp 383 in a 2 bolt main 350 block. You could take your 400 crank to a machine shop and turn down the mains to fit the 350 for about $100. You could use 5.7" rods from the 350 or you can use the long rods out of the 400, either way you will have to buy pistons that have a shorter top to pin measurement than the 350 piston. Keith Black or Speedpro hyperutectic are good and will support NOS if that interest you. You have to relieve the block a little for the crank throw in most cases with a die grinder and the 383, like the 400 is internally balanced, so you have to fit the 400 harmonic balancer and flex plate/flywheel.
But I am serious, come on over to my shop, I'll sell you my $3400 400hp 383 to you and will take your 400 motor. I would build it to 450hp as a 406 daily driver and stomp all the equally built 383s.
I built a 383 for my 84 4X4 Suburban. I pieced it together from several different motors that I had. It ended up being a killer torque motor. I had Edlebrock build me a cam just for my application. The 383 needs smaller lobes because of the longer stroke in the 350 block. I gave them all the pertinent information like vehicle weight, type of trans, gear ratio and they built a cam just for me. Works GREAT! Those 2.02/1.60 double camel hump heads help it breath. It came out 375 HP and a whopping 455 Ft.Lbs of torque. I'm running the truck 4sp tranny (1st is granny). While I had the motor out I put 73 1ton 4X4 axles and springs under it too. With my parts the machining and motor assembly cost me $2200. The GM truck 383 with 325Hp and 415 FtLbs costs over $3700. Hit those swap meets or your local junk yard and start scrounging, that's what I did.
Good Luck,
Vic
1 - 12 of 12 Posts
