Rippin Ron
Hello Ron. I guess I was not clear enough in my last post. I dont have a 383. I have a 406 soon to be a 421. The cam specs and cam timing, I'm not prepared to discuss, but it was the same with the Performer RPM and 750 Holley and all the way through to the TPI that I am now running. Heads are nothing special. World Products Torkers 175cc intakes 68cc chambers straight plugs 2.02 1.60s. Compression is calculated at 9.78 to 1.
The base manifold is a production unit, but ported to match the 1.665 id runners. When porting, there is plenty of meat to go that far. you just hve to work a bit away from the common wall. I am down to 0.090 between the two runner passages, but as long as there is a wall between them, thats all that matters.
I did epoxy up the complete EGR passage and run gaskets without heat crossovers.
As for the injectors I did say I started with 24 pph injectors. And to ne exact, I am not running a typical adjustable fuel pressure regulator. The unit in the pictures however is not my unit. That is one with the same specs as mine, but it is one I built for a customer. As you can see, in the pictures, that unit DOES have a Holley Adjustable fuel pressure regulator. Holleys are the only ones to une in my opinion because they come with a new diaphram, and they use a thumb wheel to adjust the pressure not a bolt and jam nut. I use an aeromotive remote regulator and also 2 fuel pressure guages. 1 in the fuel rails and 1 at the regulator.
I guess I'm not sure what you are driving at when you are saying that regardless of the breathing problem I am going to need bigger injectors and adjustabe regulator and a custom tune. This unit is already running. I wouldnt need an adjustable regulator at all with the megasquirt. I could even be running at 30 psi instead of the 42 that I am running.
My unit has been running for roughly 8 months and we have been driving it in the city, on the highway and even at the track and towing w 4000 lb trailer. The unit operated flawlessly now that it is tuned in.
