Take a look at CompCam CL-12-211-2 Magnum 270H grind. I chose to go flat lifter on my 383 build.. used a 2400 RPM lockup converter on my 700R4. It's got loads of torqy starting at around 1,300 RPM.. I don't think I've had it any higher than 4,000 RPM since I built the car. I made the selection off of Comp cams website where you input all sorts of data to make the selection and it turned out really nice..
On my website the first gallery gives you an idea of what it sounds like Plus if you then also scroll down to building the engine you can see what all went into it.. over 3,000 pictures and videos on my site... keep us posted!
49fordcoupe.smugmug.com
PaulsPics
Check out how to build a classic 1949 Ford street rod with modern features and power and convenience you never thought possible. With a 383 SBC Stroker engine, S-10 front frame, Jaguar XJS/XJ6 rear end, air conditioned, power brakes, and power steering.
