I've been doing research for a few months now and (assuming the block I have checks out good) have decided to go with a 383 Stroker. What I'm wanting to end up with is something that will turn my Monte into a high 10's low 11's car (3600lbs)
I'm using a combination of a couple of builds with parts that I "think" are slightly upgraded but I may be botching the whole mess. Builds 71, 93, 114 from here. are what I'm looking at.
I have a 4 bolt 350 block that if it checks out will be what I'm using, I don't have any history on it yet.
AFR-1067 227cc Racing Heads (76cc 2.100in 1.60ex)
I figured I'd order these with valves etc already installed.
I want to use a forged, crank, rods (6.00in), and pistons (was going to use Eagle 4340 parts for the crank and rods until I heard about some issues with them) Pistons I've picked so far are KB-SLD Dome -6.3cc (KB733KTM is the kit) which with the calculator on their site say I should be around 10.5:1 with rough guesses on block work.
I picked 2 cams:
Comp Cams XR280R (12-771-8)
or
Comp Cams 300AR (12-705-8)
I'm just not sure if they are too much or not enough.
I've got 2 carbs picked out:
Both are Holley 4150 Street HP Carbs
80529-1 750 CFM Vac. Sec
80509-1 830 CFM Mec. Sec.
I've read a few things on people using the 750 with the 830(??) base plate and getting better performance. Is that an option? Or would just going with the 830 be better?
I haven't decided on an intake yet 2 of the builds use an Edelbrock Victor Jr. but I know that air is the life blood of this motor and I'd like to keep the whole thing as low profile as possible, but if I have to cowl the hood I have to cowl the hood. What are the advantages to using a tall intake?? Is there a better option with the stuff I've kind of picked?
From what I've read so far a 383 will scream as long as it gets enough air/fuel and the lower end is strong enough. I'm just not sure how to match parts and don't really want to do the whole trial and error bit with $300+ parts. Have a hay day, I haven't' bought any parts yet all I have is the block and I'm not even sure if it will check out. Just where I'm starting for right now. I don't plan on using any Boost or NOS. I'm just looking for any idea's or what you guys would do trying to get this car into the 10-11 range. And once I get the motor all worked out I can then move on to what transmission, rear end, gears as all this will be dictated by what the motor puts out. And that is a whole different discussion.
Thanks!!!
Andrew
I picked 2 cams:
or
Thanks!!!
Andrew
