hitting oil pan 383c. i.chev
not all pans are created equal,many diff ones for dif gm models, my 383 hit on one small spot so i took it to the anvil and fixed it-- 2 min job,BUt i checked this on the motor stand dry w 4 -6 bolts in place, ah yes forethought is great, someone should have told you. So now what? well find the easiest way to compare yours to others etc. new or junk yard, im assuming that ball peen job wont work, this time put it together w radio shack magnets on pan bottom in or outside and on your oil filter which you need to change 2-3 xs right after break in,how did you break it in at 2200 rpm for 20 minw the bad noise?? hope this helps ron
