I have a 350c.i.,30 over and a 400 crank to put in it.I would like to know what the best rod and piston combo to go with it to keep compression in pump gas range.
If you use the 5.565" rods that came with the 400.You could use a 350 piston.Or you could get a stroker kit.From Powerhouse.I got the recessed ones.My last 383 was 9.5:1,268XE comp cam,Vortec L31 heads1.94/1.50(Screw in studs,Comp springs),Performer rpm intake,Performer 1406 carb 600cfm.It ran real good on 91.But I could get away with 89.I dynoed it on the machine and got 407hp @5200,and 460ft/lbs torque @4000.Not sure what it made at the wheels.But it went in a 72'Blazer with a TH700-R4 and 2400 stall converter.
383 stroker kit http://shop.enginekits.com/osb/itemdetails.cfm?ID=81
I used scat 5.7" forged I beam rods made for a 383 with cap screws and ran into no clearance issues. For pistons I used Probe forged 383 dished pistons, 9.4 compression with 64cc geads. Check out their sight its pretty helpful. http://www.probeindustries.com/Pistons/Pistons_SRS/Chevrolet/Chev_350.htm
I think the 5.7" or longer rods are better and reduce side loading but i'm not really sure how important it is.
We alway use 6 inch rods in our 383 engines we have built and using a 400 crank and turning down the mains to 350 mains you may run into problems as the oil holes may end up in the radius of the journal.
