I need to know if my 350 TBI will provide the nessisary airflow for a 383. Providing of course that i have properly machined highflow heads freely routing the air.
Premium Member
It should. However if you have some heads and intake that will flow some serious numbers you might look into a larger THrottle body.
Time is short, are you ready?
Regarding the throttle body, I agree with Siggy. Depending on the cam you install, you may get by with just higher fuel pressure. You can get a 670 cfm TBI unit from a variety of sources. Also, chances are a custom chip will be in order.
I found a great TBI source at www.cfm-tech.com I am sure that there are plenty of other sources, but they seem to have a tailored selection for what you are attempting to do. Also check out Howell Engine Development
Best of luck with your project, Ed. www.edgesz28.com
__________________________________________________
Who is Jesus?.:)
