Hi, :welcome:
Welcome to HotRodders.com Glad to have you with us
You should wait until you get your kit, & test fit it, also If you use cap screws on the rods you might not need to grind(clearance)
any, & if you do it will be a lesser amount, is your block a one piece rear main, if not I would try & use (get) one
as they are less prone to leak plus it's a roller cam block 87 & up mixed FT & Roller, 96 up all Rollers.
Rich
