I'm halfway through a stroker build and hit a snag. Halfway meaning the block has been tanked,cylinders bored .030,mains align bored and honed and the head mating surfaces have been milled to zero deck height.I tapped and plugged the oil return holes in the oil galley and installed screens in the four corner return holes.I got an Eagle 4340 balanced rotating assembly with 6in h-beam rods and JE -5cc forged pistons with gapless rings. I ground the pan rail and bottom of the cylinders to provide .050 clearance where needed to clear the rods. Now I'm ready to set the high quench 64cc aluminum heads on, order my cam and start putting my valve train together right? Wrong. I called Compcams to order the hyd.roller of my choosing(236/[email protected] and.520/[email protected] with110*lobe sep).I had all the info the tech ask for and felt pretty knowledgable until he ask if I needed a small base circle cam. BAM! All the sudden I felt like Barney Rubble. I know alot of people run a "small base circle" to avoid rod bolt contact but I have added another element to this monstrosity. I'm retrofitting the hyd.roller in a 4bolt 010 NONROLLER block using an OEM spider hold-down and "dog bones" with the GM short roller lifters.(Mostly because I was told it wouldn't work)I've done alot of research and found several people have done this on the 350 configuration using standard base circle cams.I'm afraid to order a high dollar custom grind cam that is either A) too big to clear the rods, or B) so small that the lifters drop out of the dog bones and/or oil passage.When I purchased the rotating assembly,I was told that the rods are profiled for "most stroker applications". It's been balanced already so as far as I'm concerned, grinding on the rods is out. Has anyone out there run the 6in Eagle H-beam rods in a 383 stroker application without a small base circle cam successfully? What is the standard base circle of a smallblock cam? I know alot of headache could be spared by using retrofit roller lifters but I've heard horror stories about link bars failing and I want to build something not many have.I've e-mailed Eagle twice on the clearance issue and still haven't heard back from them. Any opinions or experiences?
