· Registered
I am looking for some help. I’m getting ready to have a 2000 Corvette cradle narrowed to fit underneath my 1939 Chevy coupe. To figure out how much it needs to be narrowed. I need an outside dimension tire to tire that someone might have. Not sure how much room I need so tires don’t rub on the fenders. Thank you for any help.
· Registered
I have found 58" hub to hub is a good point to start. Making tires fit is a function of the rear width, wheel offset and of course tire size. I used a 76 Granada 8" that was 56" hub to hub, added 1" adapters to convert Ford to GM and the stock 15" rally wheels. The 36 - 39 chassis are essentially the same dimension.
Wheel Tire Car Vehicle Automotive lighting
· Registered
Yes I would seriously forget about numbers and measurements until you have the actual tires/wheels you are going to use, and they are mocked up under the fenders of the actual car you want to put them in at the ride height you want and in the position where you want them. When you've done all that and it's sitting there in front of you and looks right and you haven't had to rely on anyone else's experience or opinion (not that it's probably not inaccurate), then and only then get a tape measure out, do between the wheel mounting surfaces which is all you really care about and hand that to the guy doing the rear. I've driven myself nuts adding and subtracting numbers gotten from whatever collection of sources to arrive at what is in part a subjective thing anyway and have the car not look right when it was all finished and have to do it all over again.
