I have a 91 camaro that came from the factory with a 5 speed. The previous owner swapped out the 5 speed for an auto. Im trying to switch it back to a 5 speed with a tranny from an 87 trans am. When we pulled the auto off, we discovered that the engine was also replaced; with an 83 year model. I made the mistake of buying everything I need (tranny, clutch kit, flywheel, master/slave cylinders, etc) before looking at the engine. The flywheel has a diferent bolt pattern than what is on the engine-which throws everything else off. Is there an adapter plate or conversion kit to bolt up an 87 tranny to an 83 engine on a firebird/camaro? Thanks for any help!
