I've got a '93 Chevy 2wd (5 speed manual, no cooler) w/ an 88 x 26 inch plow on the nose. It has a mild cam (not sure the specs anymore, but with 3.73 rear gears it has to hit almost 1500 rpm to "pull" hard. After I put the cam in, and after two thermostats (190*), the temp gauge would sit at 210 all the time. Timing is set dead on according my timing light. After a recent 200 mile round trip, it dropped to about 190 -195 before I put the plow on.
Now all of a sudden with the plow on it will run between 160 to 150 and it hit almost 260 once. I know the plow directs snow above radiator, but it does this sitting idle, plowing, or heading down the road at 45 to 55 mph. Also, when the temp gauge hits about 215 the heater starts blowing cool air (no, the a/c is not on, I checked) until it gets to about 225. If I run a lower gear and higher rpm, the temp drops down to almost normal. The whole cycle (cool to hot and back) takes about 5 to 10 minutes.
I'm leaning towards a bad head gasket, but I'm hoping I'm wrong. Any thoughts on what's happening? Thanks in advance.
