1 - 7 of 7 Posts
When doing away with the computer on a '94 vortec 4.3 engine, how can I still use the computerizied distrubutor? I was told that all that I needed was to keep the coil wire to the dist. module hooped up and forget the otherside of the module, then run a hot wire to the coil, set the timing to about 18deg. and fire it up and go. Will this work or not? It sounds a little screwy to me.
Doc here, :pimp:
It will run...
BUT have no performance..It will have no EST, which controls the timing advance/ retard..which is needed to "Keep up" with the changing demands of the engine.
You need to go to a pre 1980 GM HEI, or an aftermarket with advance features..(either vacuum or electronic, or mechanical) The pre 80's HEI is the cheapest route..
Doc :pimp:
You need to use a "conventional" HEI distributor for the 4.3L V6. There are aftermarket units, or you can use a distributor from a 1985 Astrovan. They used a carb and conventional HEI. Do not use a 200-229 Chevy V6 distributor as they aren't even fire. The computer controlled unit won't work.
Bob
Thanks for the replies. but there is not enought room for the HEI. If I cannot get the orginal to work I will have to go aftermarket. The fellow who said it would work races his, he said he used about 36deg. advance for it. If that's true or not I do not know.
Doc, the 4.3 was not made before '80. The 229 and 231 will not work I am told. The early 4.3 dist. were big, like all the HEI's.
I have read some threads from a guy called Ignition Man. He seems to have done something with these but I don't know what. Thanks.
Doc here, :pimp:
Oops ! My BAD!!! forgot about the 4.3 was a V6.. :spank: always thinking 8's..
Sorry about my wrong info.. :sweat:
MSD has some good solutions for this..go to their website and have a look at the product line..
ALSO, the guy your talking about is Dave's Small body HEI's in Nevada, just do a search under that and go to his site for what he provides..
Sorry for the confusion..
Doc :pimp:
Doc here, :pimp:
Your welcome
Let us know what you come up with.
Doc :pimp:
1 - 7 of 7 Posts
