Can I eliminate the balance shaft on 96 "W" 4.3 V6 if I balance the rotating assenbly & what bobweight total should I use 50%????
It will shake more than it has because a 90* V6 is out of phase 120* firing with 90* vee angle. All the old V6s were like this, though.Buildengines101 said:Can I eliminate the balance shaft on 96 "W" 4.3 V6 if I balance the rotating assenbly & what bobweight total should I use 50%????
DoubleVision said:I`m not sure of the balance shaft engines, but the non balance shaft engines balanced with a 36% bobweight. I just had my 4.3 crank balanced to this spec. Thanks to Machine Shop Tom for this information.
I don't know anybody who hot rodded V6s.DoubleVision said:You mean you don`t know? I`m shocked. Ask Tom.
That I'm not sure of. I'm an Olds guy normally. GM has been going through a phase of trying to "refine" their engines for smoother operation, so I think the balance shafts have been creeping in over time.fast68 said:so all the 4.3L have them ? i thought it wasonly the Z vin code ones that did, like in my brothers 92 s-10
As I noted, the ideal V6 should have firing pulses ever 120 degrees of crank rotation. The "odd fire" V6 with 90 degree cylinder bank angle uses a crank with three rod journals, each 120 degrees apart. This yields firing pulses that are 90-150-90-150-90-150. You can see where the vibration comes from. In mid-1977 Buick went to a crank that "split" the rod journals on the crank. Unfortunately, this weakens the crank, so they couldn't move them far enough to get firing pulses that were exactly evenly spaced, but it was a lot smoother than the original motor. Note that the odd-fire motors use a distributor cap that looks like a V8 cap with two wire missing. The even-fire motor uses a cap with all six wires evenly spaced.so if the firing pulses(firing positions??) ar enot 90 or 120 degrees apart on the old 90 degree v-6 engines(200, 229, 262) then what are they ? how far off from 90 or 120* are they ?
For the Buick motor, that was 1977. I don't know when Chevy did it with the 4.3 or if that motor used split crank throws from the beginning. Conventional thinking is that a truck can have a rougher running motor than a car, but today's truck buyers want their trucks to be just like a car, hence the need for balance shafts.ive read somewhere before that some years were even and some were odd
joe_padavano said:The problem is that even with split crank throws (as pioneered by Buick on the even-fire V6) you can't get firing pulses that are evenly spaced. The split crank throws make it better, but it isn't perfect.
Offset ground cranks do actually fire at an even 120.
But the rotational imbalance is still there.
xntrik said:I know that's the desire, and maybe the current offset cranks are designed to provide this but I distinctly recall the article about the even fire Buick in 1977 that said they didn't quite get the pulses evenly spaced. This may have had something to do with the then-current rod bearing size or it may just be my bad memory after 30 years...Offset ground cranks do actually fire at an even 120.
