A friend came to visit in his 1986 Chevy with the 4.3L V6 TBI injected car with twice around on the clock. It ran fine when he arrived. When he left, he returned a few minutes later because the car was bogging down on the slightest gas, shaking, and occasionally bucking with a light backfire.
I went for a test drive and it acted like another vehicle I once had when the ignition system in that car was running on the "start" reluctor because the "run" reluctor or pickup had gone open circuit. The engine would cough, bog or backfire if gas was applied at low rpm or under load. It ran better at higher rpm but not great. It picks up rpm slowly once spinning fast enough to get past the bogging and sputtering. Even then, more throttle or load caused protest from the engine.
We looked around and no vacuum lines were loose. Vacuum measured 20 at idle and steady. I didn't see any timing marks on the flywheel to check the timing and it was dark, cold and time for him to leave anyway.
We have no documentation for this car... so no idea about the ignition system except that it is obd1 computerized with two thottle body injectors. Wires look okay. Cap looks okay to. Are there two timing pickups, one for run and one for start in this car? It acts like the timing is way late. Any other ideas what to check?
