does anyone know if a adjustable 4 link set up will fit under the stock frame without mods? i know i`ll probably have to cut the bed but i wasn`t sure if it would work under the stock frame. my second question is, if i use a 4 link, will i need to remove the rear trailing arm x member? will it make the frame unstable if i do? thanks.
... & Insanity Ensues .....
how well it will fit will be decided on how low your ride height is planned to be
for the most part, the height of the frame is the gap you will need to fit the 4 link, as the frame is about 5 inchs tall, and thats about how much the 4 link bracket extends above the diff. housing
if your lowering the truck enough that you have to notch the frame to acheive the proper axel travel, then youll also have to notch the floor for the 4 link travel also
thanks for the info. i think i`m just going to use a frame kit from alston. that way i can lower it to the height i want and run a bigger tire. thanks.
