I am about to fabricate a triangulated 4 point suspension system for my 67 nova . Can anyone share some pro's and con's of that type of set -up? I am trying to get away from the pan hard bar .
Have you looked at a watts link?I am about to fabricate a triangulated 4 point suspension system for my 67 nova . Can anyone share some pro's and con's of that type of set -up? I am trying to get away from the pan hard bar .
I find it interesting you would not recommend Heim joints. I have read that using them eliminates the binding in case of misalignment. I purchased some high end joints from Rod End supply that they recommended for the application and plan on using 3/4" shoulder bolts for the precision fit. I own a manufacturing facility and have access to lasers, cnc mills and lathes so fabricating the components will not be an issue. I have also read that the top bar should be about 70% in length compared to the bottom bar. Do you have any experience with that ratio from top to bottom?Lots of info about exactly how to set up a triangle 4 bar on line. Here are a few things I've learned setting them up. First, the upper bars must be angled out to the frame a lot. Because they are the ones that will keep the rear end from moving side to side there must be a greater angle. The top bars should also be pointed downward (back to front). This will prevent the front end from popping up on launch. Bottom bars parallel to the ground. Make SURE all your joints are tight. Any bracket to rod end loose fit will cause ill handling. If possible do not use heims joints.
Here are pics of what I have so far. Top link is 19.5" and the lower is 24" . All dimensions are ctr.-ctr. Any thoughts?Thanks for sharing that! I will make sure everything is solid . When I get it together I will post some pics..
I have 3 degrees of forward down angle at ride height. The rear end seems to hold the three degrees through out the range of travel so I think the difference I noticed in the model is pretty accurate. As far as the shocks are concerned, I plan on using grade 8 bolts but if I have trouble the air shocks are always an option and will bolt up to the brackets I made. I do like the idea of adjusting them on the fly..Good deal of spread on the upper bars which will keep the rear end in place just fine. Only thing I can't see is the amount of down angle the upper bars have. As long as when you launch the front end doesn't pop up much and you have lots of bite then I think they are just fine. Lots written about the focal point but I really don't expect to see you on Street Outlaws.
Just me, but I hate coilovers. Note that the whole rear of the car is suspended on just two bolts. I snapped one off on a mis-matched bridge seam. Air bags are adjustable from the dashboard with a push of a button whereas crawl under the car to adjust the coils.
