I have a small block 400 i been told was bored .030 over. i'm really not sure, but to be safe, i'm going to assume the bottom end is stock. the heads are world sportsman II 200cc heads, the intake is a torker II, which i'll probly be swapping for a performer rpm. i don't know much about the cam either, i wasn't given a cam card, but through motors i've had and built in the past, i can make a rough estimate that the duration is in the 280 ballpark, and probly somehwere around a 500 lift. i checked the timing at idle, and it is 11 degrees advanced. my question is where is the safe range for maximum rpms? i want to set a rev limiter, but don't know where to set it at. the motor makes power past 5,000 rpms, but i don't want to push it too far without some advice or guidance from someone who knows this kinda information a little better.
any help would be appreciated.
