so i got a new project its a 78 k5 got a th350 tans rebuilt i did it my self
stock stall converter np203 behind it however the engine came as a shock to me ive never torn down any thing but a slant 6 till this i assumed i havea 350 so most of my parts went to that turned out after scrapibng the gunk off motor was a 817 casting 400 2 freeze 2 bolt mains so due to neglect i decided id build it up a bit
parts list ive got to work with so far
carb edlebrock 1406 600 to 699 cfm{changed to manual choke}
intake edlebrock performer dual plane {came with truck}
heads were toast warped so i found a nice set of rebuilt
993 casting gm goodwrench heads with the larger valves 2.02"/1.60" 75cc
summit 1103 cam and new lifters and springs
double roller timing chain{almost gear drived it budy convinced me not to}
400 block was original to the blazer shocking to me the cylinders and rings checked out no machining neccesary standard size bearings bought a new set retaining stock pistons they looked clean new rod bearings
new scat crank shaft [better counter weight design lighter] {original crank had damp bolt broke off on it and was half done with heli coils ... not standing for that}
extended oil pan
comes out thrue a pair of hooker comp headers long tube
2.5 pipe
to thrush glasspacks dumping out just before rear axle
dizzy is a summit SUM-850001R
all apart right now but test fit seems ok. now while apart any suggestions concerns i should look for primary use is a camp vehicle maybe some mild off roading live in arizona after all.
extended oil pan
2.5 pipe
