I have 1 head off. Bad headgasket install ,bfo, caused loss of compression on one cylinder. Want to take head and have the cylinder side and the exhaust side machined true. Had to remove broken bolts with heat never been removed before, and a chunk of headgasket missed in former repair ie the compression loss. Have two broken exhaust manifolds but only trying to get it running on all 8 right now.
Is it OK to true one head on a 403 and can I use 400 pontiac exhaust manifolds and the y pipe that goes with it on my 403? I know other head will have to come off if the bolts don't come out. Don't want header expense right now also this thing is low enough as it is. Don't want to drag the ground with exhaust. Im planning engine mounts as well. Thanks for the help.
