1 - 20 of 27 Posts
Want to hear any feedback on what FT Hyd. or Solid cams some of you are running in a 406 sbc, I'm at 3200 lbs. with me, its a 78 cutlass, I tried a larger Chet Herbert FT Hyd. cam but it had way too much overlap & was rated for 11.5.1 compression, car didn't respond well & it was a bear to tune, I'm either looking at the comp XE line, possibly a Lunati, I'd go Hyd. roller but just can't afford it right now. Hers is the engine combo.
406
10.4 compression, 205 cranking pressure
Iron Eagle 200cc heads
RPM intake, 750dp
1.5/8 headers
HEI ignition
I have choices of these 2 converters.
10" 2800 stall or 10" 4200
9" with 3.70 gears, 28" tire, but also have 26" ET Streets.
Google "Tunnel Ram 406"
I'm using a Comp Cam 280HFT with 1.6 rockers on my 406 with 11:1 compression. It has strong throttle response and a mild lope to it. Just google (Avatar) it and you will hear how the sound.
Kindof wanting something that'll pull good to around 5600 5800 or so, maybe i need a cam in the 230s on Dur. @50, I have run comp cams XE284Hs before with good results in both SB & BB, but they were Mopars.
I don't know what the deal is on the one 510 cam, It must have alot of overlap, It called for 11.5 compression, so that might explain why it didn't run right.
I just recently installed a 9" with 3.70 gears, i've really noticed a difference over the 4.11s, now my 4200 stall seems a bit much.
Discussion Starter · #8 ·
510/510, 245/245 @50 108 LSA 3000-7200
When using this cam it is very critical on how it is installed. .. intake closing point @.050"
The 510" lift cam will work a lot lot er if you install it like this.
Degree it in and advance it so that the intake C/L is on a 103 C/L
when measured at .050" the intake valve would close at 45.5 ABDC
It will have a ton of torque and plenty of cylinder pressure. with 10:1cr does not need 11.5:1.
further when you set up the distriutor this cam needs a ton of timing at idle
so much you can just simly lock out the mechanical advance and run full 36deg timing
It will idle nice and respond right off idle with the 4200 stall.
It will GLH.
You cam was likelu not advanced on install correctly or at all and the distributor curve was all wrong
a stock distributor curve will not work.
Install and set it up like this and it will do what you wanted it to do.
timing at .050" when you degree it should be open 19.5 BTDC and close 45.5 ABDC intake
exhaust open 55.5 BBDC ex close 9.5 ATDC
in C/L 103 ex c/L 113 it will be "5 degrees advanced" when installed like this.
makes a big difference.
Your 224-234 112 cam will run best when installed 5deg advanced 107 in 117 ex C/L's
.050" timing would be 5 - 39 in 54 -0 ex
with this cam recurve the distributor to have 24deg base initial at idle and 36deg at full advance
thats a 12deg mechanical advance curve.
This cam likes a 3000 stall. a 3500 stall is not too much, a 1700 is not enough.
Vacuum advance can and should be used too with both these cams ..limit to 12-15 deg max at highest vacuum use ported vacuum.
Either cam wil GLH when installed and set up right. The .510" will make the most power.
especially once installed correctly and the distributor corrected. (locked out is right for this one)
Use a 4.5' rated holley power valve with this cam.
the only reason this cam did not work well for you was the setup and installed position
Cam phasing.
So your saying even the small cam should advance 5*? I have the int. timing on this cam at 22* & 36* total, The larger cam i had the dist. locked out, plus i advanced it 4*, It ran better but still not great, The low speed/idle was the worst, It only pulled 5-6 inches vacuum which i though was low, I'm sure still needed more advance, plus i think the timing needed to come in earlier also, I ran a 3.5 PV, When i 1st. got it running to break in the cam it was a mess, I played hell getting it started, It acted like the timing was really slow but it was up there, so that was telling me it must have been way off.
I need to go back to the drawing board on the larger cam, In a couple of outings it pulled to 6800, thats a bit much IMO running stock rods/bolts,
maybe you should list the other components in your engine? carb size,intake style,headers primary tube size,exhaust system,ignition? maybe there are a lot of problems. Ive never had big issues with camshafts,put them in and go fast. I prefer solid lifters for many reasons,,, never had a cam that was too big
Discussion Starter · #10 · (Edited)
Didn't you see my 1st. post??
I normally don't have issues with camshafts either, just line up the dots & go fast, Now with this little cam i did run some 7.9s in the 1/8 shifting at 51-5200, my best MPH was 108, so its not to shabby, but it ran slower with the larger cam when i'm sure it should have ran better.
hei stock is great to 5,000 RPM,after that it needs help. 1 5/8 primaries are great for low to moderate power,750 DP is a good carb. should be a tire melter. what shape are the valve springs in?
Discussion Starter · #12 ·
The HEI is the Procomp, I know not the best, but it has not missed a lick, even at 6800 rpm, 1.5/8 headers i know are a bit small for the 406, The springs are like new, there doubles with pressures at 132 seat, 320 at .500 lift., It IS a tire fryer no doubt, just doesn't put down the ETs i think it should, my main concern was the cam (510) not perf. well, Its like I'm wondering if its a flow in the positioning of the key when it was built, I just lined up the dots on the little cam & it runs pretty good, pulls 16 inches vacuum (in gear). The 510 only got about 6 inches when i'm sure it should have been around 9-10.
The car looks like it is performing as it should.If that is your E.T, with mufflers,its actually decent.
what I would check,or look to improve:
Do you get enough fuel at the end of a 1/4 mile race?
I believe a victor junior and 850 D.P. would add another 3-4 M.P.H.
If the manifold/carb/fuel delivery added 5 m.p.h. then,,,I would use the hooker 1 3/4 primary pipe headers.
if that helped,then I would change cams after looking what helped the most
Discussion Starter · #18 ·
The MPH in the 1/8 was 87 at best, I'm at the point of just running a 100 shot & call it good, but i'll need to re-install my 2800 stall, the 4200 just seems a bit much with a 3.70 gear.
Speaking of 3.70 gears, theres a few well in the 11s with these gears in there G bodys with 406s.
Discussion Starter · #19 ·
It WAS trapping around 5900 with the 4.11s & a 28" MT DR, I did have the car weighed on a reputable scale at the local rock cuarry plant, I wasn't too surprized of its weight, Its a bare bones cutlass, not the fancy ones, I'm only 145 lbs., so i'm a light weight, It would be nice if the car was heavier, it would explain its slower times, Now i did calculate converter slippage & it was saying 12%, that seems a bit high, I'm getting somewhat at my wits ends with this combo, Its like what the heck, I know it should run better but it doesn't, It feels like it just runs out of steam in high gear, it just doesn't pull, but on other accasions it seems better, maybe its fuel, but i'm running a 110 pump with 8 lbs. pressure, the fuel line is all good, so is the tank.
1 - 20 of 27 Posts
