Many different engine combinations can produce the results you want. I had a balanced and blueprints 350 bored .040. Fuelie heads, 461X ported, 2 four barrels, ignition curved to match the comp cams 268. Turbo 400 and 3:73 posi in a 69 Camaro. I helped a buddy build a 455 Olds with just a cam and headers. Both cars were fun from a light. The Camaro reving through the gears while the 442 just ate up assault with gobs of torque. Amazing what 100 cubic Inches more does. The 442 had less engine work than the Camaro and ran with it all the way. Whoever got off the line 1st usually won.
Next is a 265 bored .060 with 11.5 compression, ( must index the plugs to avoid pistons hitting spark plugs & closing the gaps ) since the 461x heads have a low plug location, line bored, decked, crank turned and indexed with stroke corrected, 461x fuelie heads, ported, screw in studs, guide plates, victor junior with 750 holley, vacuum secondaries. A lunati cam 300 duration .500 lift, 110 LSA, 230 @ .050. Running steel shim head gaskets .Running a turbo 400 with 3500 stall and 4:56 posi. Different animal all together. It was built for high rpm since small cubes have no torque. It is fun to drive and I expected no torque at low rpms. But at 3200 on up it is a wicked beast. Just goes to show what you're after, someone has probably perfected it. You just have to find him.
