Example: a 4.155 x 3.750 (bore x stroke) .030 over SBC 400 block, zero decked will yield about 10:46 compression with a .040 thick head gasket at bore size, or about 10:58 compression with a .035 thick head gasket at bore size, using a 64cc chamber and the following pistons:
http://www.cnc-motorsports.com/product.asp?ProdID=18761&CtgID=18757
I have these rods on order and flat top KB pistons for my 400, because my heads have larger chambers.
http://www.cnc-motorsports.com/product.asp?ProdID=1125&CtgID=
Edit: These KB pistons have a 1.133 compression height which is .008 higher then some other available pistons, so you have to take that into consideration BEFORE having the block machined. Get the crank kit before any machine work is done...
With that said and the block zero decked for the above pistons (9.008 deck height). The compression examples are correct.
