408 SBC built by me about 5-6 years and 30k miles ago. Has Edelbrock Performer RPM heads that were new when the engine was built. Has been driven fairly hard for most of those miles. Engine is currently in an 80 Malibu that runs mid-high 12's.
It recently started running rough and found that #5 spark plug was oil fouled. Looking to diagnose the reason. Pulled the carb and used my inspection camera to look down the intake into that cylinder. I didn't see any oil in the intake tract as I was looking to make sure it wasn't burning oil due to an intake leak. I did notice that all of the intake valves seem to have the same amount of carbon on them.
Next step was a compression test. All cylinders were between 130-135psi on a cold motor.
I'm thinking the next step should probably be a leak down test?
I'm hoping it might just be valve seals, but I realize it's probably wishful thinking. Hoping it's not guides or a bad ring.
Any ideas?
Any ideas?
