i was wanting to know if anyone knew what engine would be a good swap for my 82 cadillac , instead of the stock 4100
Let's start with fundamental question - WHAT model Caddy? If it's FWD, you're stuck with the transaxle, which uses the metric 60 degree motor bolt pattern. If you do have a FWD, consider swapping a 4.9 Caddy or a 3800SC Buick. There are also some 5.3 liter LS-series motors with the metric bolt pattern. These were used in FWD transverse installations like the Bonneville.stankin lankin said:i was wanting to know if anyone knew what engine would be a good swap for my 82 cadillac , instead of the stock 4100
Stop hijacking and start your own thread. bro82 coupe said:we'll u kno that sounds good but do u kno if i can use the same trany i have or will i have 2 put the entire drive train im thinking i will have to kus of all the balls a 500 has. sinnce the 500 would be a gas hog is it possible to put a two banger carb on that bad boy thanx 4 da reply bro
