My 57 Nomad with 427 bb 11:1 forged TRW pistons w/GM aluminum oval port heads. I guess they are same as Edelbrock with 2.25 intakes and 1.88 exhaust, Cam is Crane 228/236 degree 114 lobe separation .530/.551 lift. Stock '60s distributor (nice tight), now has Pertronix module added to it. Carb is 670 cfm Holley right out of the box. Weind intake. 4 speed tranny and 3.73 gears.
What plugs should I be running in it? At present I have Ford Racing plugs tried both AR3935 and AR3934 gap is .037". With both plugs engine has a bad miss, break up above idle when driving it. Engine is new and this combination is the only thing I've tried. I've changed the points over to pertronx and new 8 mm solid wire core wires and new cap. Also tried different coils. Results in no difference. Tried timing between 10 - 18 degrees initial, vacuum advance is working fine. Suggestions ?
