Hi guys,
I have a '68 vette 4 spd manual that has a 327 with a 13:1 compression. It was modified in '85 by some old school guy that was in drag racing. I want to put a 572 engine in it :mwink: .
I have a 427 Tall Deck engine sitting in the garage. The block is in excellent shape with has std bores and you can still see the cylinder honing marks. I want to bore it from 4.25 to 4.5 and dump the std crank for a 4.5" crankshaft. Probably run around 10:1 compression. Also I want to go with aluminum heads, water pump, intake, high cam, etc. I want a screamer engine that has more top end RPM that can rev easily around 6000 rpm.
My questions:
Boring the block, can I safely do that or will I have overheating issues with the car running too hot?
What aluminum heads are good to with? Is this one okay? What other can I get for around $1k? http://cgi.ebay.com/ebaymotors/BBC-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
How about this kit off ebay that includes the crank, pistons, rod and bearings for around $1,700? http://cgi.ebay.com/ebaymotors/BBC-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
What cam is best to go with? I have no clue on that but my car is a 4 speed manual and I would like a high cam. Something like in the current 327 engine: http://www.youtube.com/watch?v=_T-CG7FwoDo&feature=channel_page
Should I get a higher compression or lower? I am in AL and I think 93 oct is the maximum you can get.
Or, do you have any other suggestions of what other better bore/stroke combo.
Thank you,
Gio
My questions:
Thank you,
Gio
