1 - 2 of 2 Posts
tryin to get some info on how to build this 427T. using the stock heads ( A63 ). with stock flat top pistons and crank. found the spacers and a street intake. i have heard that i either need the intake machined or a adjustable collar distributor. tryin to find out how much needs to be machined out for a normal distributor to work.
.385". MOST intakes will not take this kind of cut. MUST have re-inforcement welded into underside dist area.
You are better off machining off the dist. ring and fabricating another.
Don't expect much from this combo. Four ring pistons and tiny valves/ports are only good for 4500 rpm.
1 - 2 of 2 Posts
