1 - 9 of 9 Posts
i am trying to install the wires on my 1970 chevelle with a 78 454.
i have read of different firiing orders, and i remember there used to be a chart showing the distibuter and the cylinder numbers but i can't find it!
any help would be fantastic
thanks
erhalt:smash:
Timing
Doc Here:pimp:
HAPPY THANKSGIVING!
To Time your Distributer Properly, Try this:
  • Bring your #1 Cylinder up on Compression TDC.
  • Timing mark should be TDC
  • Both intake and exhaust valves should be closed (slight play in lifters)
  • Locate #1 Plug on the cap and set the rotor tang at that position. (mark the distributor Body with a pen at that point so you can see it)
  • With the rotor pointing to #1 plug look at the bottom of the Distributor shaft and note the location of the oil pump key slot, using a long slotted Screwdriver set the pump shaft approx. that position.
  • Install the distributer. Because of the diagonal Cut of the drive gears, The rotor will turn as you insert it, so figure the distance between the amount of turn, and the line you made on the distributor body and rotate it back that amount, It Should Seat Exactly on #1 on the cap, or very, very close.
Check your Firing order.
The spark plug locations are :
Driver's side front is #1,
Passengers side front is #2:
IE the left side will be 1 3 5 7,
The right side will be 2 4 6 8.
The Stock location of #1 plug on the Cap, should be, about 5 O'clock.
Direction of rotation is Clockwise.
Firing Order is: 1 8 4 3 6 5 7 2. (see photo)
If you have this right, It should Fire right off!
Set your Timing with a light, check to see what the setting and at what rpm you need to be at for your engine, And be sure the Vacuum advance line (if so equipped) is removed and the Vacuum line is plugged.
happy holidays!
Hope it Helps!
Doc :pimp:
HEEEELLLP!!
I AM A COMPLETE IDIOT!
I HAVE WORKED ON THIS TO LONG I UNDERSTAND THAT THE FIRING ORDER FOR A 454 IS 18436572
HOWEVER I AM NEEDING TO SEE WHAT WIRE GOES WHERE ON THE CYLINDER HEAD!!!
I AM A EYE SURGEON...............THINK I COULD FIGURE THIS OUT NOPE!! I AM TO DUMB!
wind & fire = guides to power
Dumb and ignorant are two entirely different things!
2 4 6 8 passenger
Front
1 3 5 7 driver
Discussion Starter · #8 ·
THANKS FOR THE HELP NEED A LITTLE MORE!
THANKS GUYS FOR THE HELP.......
I HAVE FOLLOWED TO THE BEST OF MY ABILITY, BUT THE CAR WON
'T START AND KEEPS BACKFIRING WHEN I AM TURNING IT OVER.
I AM ENCLOSING A SHEET THAT I AM ASSUMING IS THE WAY THIS THING SHOULD BE DONE...........AM I STILL WRONG?
http://www.summitracing.com/tech/charts_guides/firing_order/V8_firingorder.pdf
I am assuming put the numbers in the circles run wires from number to corresponding number?
am i right
really thank for all of your help!!
eric
LOCATIONS
Doc here: :pimp:
On the distributer, rotation will be to the right (passenger side of the car) 1 right 8 right 4 right..etc..
Don't feel bad...My optometrist is Constantly loosing his white tipped cane...:D LOL :D
Sorry, don't have Winzip on this confuser...the file won't open for me.
Doc :pimp:
1 - 9 of 9 Posts
