bondo said:
What Theory,..??....
This is a Righthanded 454,........
The point is not how it moves the cam, but that the cam can't be the same. If you rotate the crank in the opposite direction, and use that gear to move the cam in teh standard direction, the cam STILL can't be the same. Reverse rotaton cams HAVE to be different unless you use an entirely different crankshaft to mirror the reverse order of the cam events.
If you have a standard crank, the order in which the pistons move is fixed. A standard rotation cam has events that support that. You have flexibility in which TDC gets which event, as is the case with things like the 4/7 swap.
Reversing the crank does not support the same TDC events. For that reason, you cannot use the same cam, regardless of which way you turn it.
I stand by what I said... reverse rotation engines require a cam timed for reverse rotation. Period. The only way of changing that fact is if you use a special crankshaft with throws that support the forward cam timing events on a reversed crankshaft. No physical way of getting around that.
but... I do appreciate the pics... I didn't know of a reversed cam like that but I learned today. but, the fact remains that if you have a reverse rotation crank linked to a forward rotating cam, the cam cannot be timed like a standard cam. Reverse rotation is 1-5-6-3-4-2-7-8 and forward is 1-8-4-3-6-5-7-2. If you put them both on one and rotate, the crank is ready to fire #5 while the cam is making event for #8.
