Started my racecar up to let it run last night and the oil pressure at idle was around 10psi. I thought this was weird since the engine used to idle at around 50 psi on start up when I first put it in the car. The oil pressure will go up if you give it gas. I pulled the valve covers and noticed that the front four rockers had little to no oil on them. Am I crazy or is this a sure sign that I've got a spun bearing or that my bearing tolerance is too wide? I'm seriously considering pulling the engine out and going through it. I dont want to damage it more if something is going on. I plan on cutting open the oil filter to see if there is metal in it. Any advice you have would be appreciated this is my first engine build.
