1 - 8 of 8 Posts
Premium Member
Got this 454 in a Henry J and not sure what compression ratio it has. Any ideas given these specs. PO says 10:1 and 538 HP but I think that's a little high. Really don't want to pull a head etc to get all the specs.
454​
Cast# 361959 73-85 car/truck
454 + .030 = 460 ci
Decked, align honed, balanced
Heads 336781
2.065 intake valves
1.720 exhaust valves
Comp cam #11-000-8 cb hr/sr roller
Grind# 3348b/3349b hr 108.0 + 4.0
Lobe lift in. .3300 ex .3420
Gross lift in. 561 ex.581
Duration @ .050 in. 248 ex. 254
Lope separation 108
HOWARDS BB CHEVY MAXIMUM EFFORT RETRO FIT HYDRAULIC ROLLER LIFTERS 91161
Pistons FED H426cp030 .100 dome
Ring dimensions 5/64, 5/64, 3/16
Dome Shape; .100 Dome w/ 1 relief
Compression dist 1.640
Deck Clearance .025
Skirt Clearance .0015
News is not good....appears that .100" tall dome is just about 10cc or so, and even figured with 119cc head chamber(it could be as big as 122cc actual), a mild deck cut leaving it .015" down at TDC results in just 8.7:1 compression ratio....zero decking only gets it up to 8.9:1.
I say 538hp is a stretch unless the heads are very good. Since they don't have bigger valves, that isn't a possibility.
I'd be amazed if it made 450+ HP
Premium Member
Discussion Starter #3
Thanks Eric, Engine Analyzer Pro shows it at 455 with 8:51 comp
Premium Member
Discussion Starter #5
I thought about it but it's stock except for the cam and ARP rod bolts
1 - 8 of 8 Posts
