i went to mortec and it says a 1 peice i know the block was made in 90 i thought they changed in 86Bumpstick said:Mustangsaly... NO and NO... The 1 piece blocks are Gen V and they as I have said before are an animal to themselves... "Avoid"... The Vortec heads you asked about are Gen VI and are good but not as good as the Gen IV ovals (781/049 castings)... The Vortec`s do not respond to the larger valves and other differences just dont give the flow of the older heads...
Also block casting 14015445 is a two piece rear main block and a good one at that... It can be either a 2 bolt or even a 4 bolt block... :thumbup:
BTW most of your 91 and up are the one piece blocks just be sure of the Gen V stuff and also they are the ones that had the most problems with valve train issues mainly due to the non-adjustable rocker setup and little 5/16ths pushrods...
Uh you might be thinking of a SBC but this casting is a 2 piece rear main...14015445...454.......78-90...2 or 4 bolt
i thought they all changed in 86 to one peiceBumpstick said:Uh you might be thinking of a SBC but this casting is a 2 piece rear main...![]()
This is true of SBC`s but not BBC`si thought they all changed in 86 to one peice
thanks wasnt sureBlazin72 said:dboyett, Mortec.com says nothing about that block being a 1 piece rear seal. It says that block was cast between 1978 and 1990. The note at the bottom of the page says 1 piece blocks started in 1991.
i have already got the headsBlazin72 said:What is a slight budget? Those heads alone are over $3000...
