Picked up this 82 454 with tore up bearings, it spun a main, cylinders have like no wear or ridge, standard bore, I'm sure they ran it low on oil or something happened, looks like a very low miled engine, I'm having the block checked.
My question is, is it possible the block is not hurt, there is "NO" discoloration on the crank/pistons/cylinders like any signs of overheating, just a crank that got tore up.
It probably isn't hurt by your decsiption, the machine shop will tell you. Even if the main saddles were buggered up a little a good hone job would most likely bring it back to life.......keep your fingers crossed.
