Elsewhere on this forum there is a long discussion from 3 years ago where I was troubleshooting my brake system. Car is a '48 Lincoln Continental with a Mustang II front end, 9" Ford rear with drums (probably '74 Torino). In the previous thread, over a period of several weeks I went from a stock 74 Mustang front disc setup to Wilwood 11" brakes and a 7" dual frame mounted booster. I was dealing with low vacuum to the booster and eventually sorted that out. Performance went from "mechanical brakes" level to OK hydraulic brake performance- nearly impossible to lock the wheels, but somewhat adequate. I've driver the car several years like this and only once had a hair raising stop when someone pulled in front of me.
I still think the performance could be better and may finally have figured out what the problem is. I've found that the brakes perform much better under severe use, such as a couple of panic stops. After warming the brakes up like this, it's possible to lock the rear wheels (still not the front) , and the front hauls you down nicely despite not locking. My conclusion is that the Wilwood brake pads are a racing formulation or close to it, so they don't perform well under everyday street use (the first stop of the day can be quite harrowing).
Best I can tell, there are only 2 other pad formulations made for this caliper and they are all more racing oriented than mine (BP-10). Anyone with Wilwood experience care to weigh in?
