Southern Man
I know I've seen this thread before but I forgot, on my 49 its changed to 12v on the solenoid it has two small poles I & S the S goes to the starter button, does the I go to the + side of the coil or to the ballast resistor :confused: any help is appreciated :D thanks,JoJo
Doc here, :pimp:
The "i" terminal is for secondary Ignition... IT goes to the Coil + terminal AFTER the ballast resistor..
The "S " terminal comes from the Start wire on the ignition, no additional wire is needed here...just hook it up.
It should work just fine.
Doc :pimp:
