That Camshaft is going to lobe like no other !!!! your Dur. is hight that you need to run a 3500 on the stall, Hope your running a good trannytsmall114 said:vary dumb question and that is i have a .650/.650 lift and 272 dur @50 will this cam jus be a rough idle or more of a really radical idle?
Oh yeah your running the good tranny what muncie is it? m21 or m22tsmall114 said:tranny is a muncie mss 4 speed. is there any tips you guys can give me on things i can do to help prevent failure of the solid rollers on the street since its a street strip? and what do you think of isky redzones or is there something else better?
Should rock the vehicle side to side. I assume you know you'll need minimum 11.5:1 static compression ratio, 4.30-4.50 gears and a minimum 4000 stall converter.tsmall114 said:vary dumb question and that is i have a .650/.650 lift and 272 dur @50 will this cam jus be a rough idle or more of a really radical idle?
Not all the time, its what size of tires your going with to that matters to.techinspector1 said:Should rock the vehicle side to side. I assume you know you'll need minimum 11.5:1 static compression ratio, 4.30-4.50 gears and a minimum 4000 stall converter.
It's not nice to fool old people.airboat said:I'm thinking the Muncie doesn't need a high stall converter!![]()
