Hi all, greetings from Tasmania, Au.
I have a 4L60 box - V6 GM combo fitted to Toyota Hilux, not long bought. The problem I have is when going down hill at any speed and take my foot off the trottle it does not change down gears, neither it will change manually. As a result, the car free wheel down hill with the only option is to use the brake, not a good thing! Access to mechanical workshop is a long way away.
On a flat road all changes happen as they should.
Any pointers as to where to start checking would be greatly appreciated
Cheers
wdl
Are you talking of a 4L60 tranmssion with a TV cable to the carb on the engine? Or a 4L60E trans, electronic controlled?
Going down a hill , the trans does not know to down shift on it's own.
If manually shifting down to a lower gear, does nothing at any speed?
you should be able to down shift manually, while applying the brakes to slow the vehicle
Cheers
wdl
Is this a 4L60E electronic control or the 700R4/4L60 mechanical control gear box?
Manual down shift, how far do you fall back on the gear command? Some of these will not manually downshift till second gear is selected.
