The trans in my '95 Formula lost any gear above second two Christmases ago. The car sat until recently, when I installed a used 4L60E that the seller told me worked fine. Well, low and behold, it has the same issue i.e. won't shift into third. Manually putting the shifter selector in "3" and applying the gas results in the engine revving, but no gear engagement. There have been a few times when I thought it felt like 3 did catch after manually selecting it, but for all intents and purposes the trans will only give me 1st and 2nd gear.
I have been getting various types of advice from people about what the problem might be, but was referred here by another member who believes that there are some trans gurus who might have an intuitive sense of what is wrong.
It seems odd to me that the used replacement trans has the same problem as the original trans. But, people are telling me that this is the 3-4 clutches, and that this is a common problem on these transmissions after about 40k miles.
I'd like to get the car buttoned up before next month, when I will have a newborn daughter and no time to fiddle with the car.
Thanks for any guidance.
