I have a 1993 s10 blazer with a 4.3 vortec and a 4l60e transmission. It always takes off in second gear at takeoff but upshifts and downshifts fine after that. I believe 2 3 and 4 gears are fine but i might just be feeling lock up in place of 4th.If the odometer is correct then the truck has 218,000. I bought a scanner and its showing a code 82, QDM solenoid A monitered voltage differs from commanded, or Ignition system fault-3X signal Problem. I bought but havent installed a Transgo 4l60e-HD2 shift kit and two new solenoids. I need the truck before winter hits and ive read that its not good to drive it in this condition. Will the parts ive bought fix it or is the transmission severely internally damaged? Also I wanted to add that it takes off in second even if the shift lever is in the D1 position. Any and all help is greatly appreciated.
