1 - 6 of 6 Posts
no idea what you are talking about.
no seal is located where the finger is pointing
There is a grove machined into the shaft at that location that looks like it would hold an oring or something. My atsg manual does list a "output shaft seal" in that area.
Crosley.. are you saying there is no seal of any sort on the output shaft?
When that trans was new there used to be a tin cup with an oring in it that was pressed on in that location on the output shaft it used to seal the opening of the yoke to keep it from filling with oil gm stopped using and Ive never seen a rebuilder put it back on
1 - 6 of 6 Posts
