Hello i am a new member, I have been browsing here just havent really seen a need to put my two cents in most of the time someone has already said what i would have said given the discussion, in any event i need some help
I rebuilt a 4L60E it had worn clutches.
I replaced 1-2 solenoid, 3-4 solenoid.
Pressure solenoid.
Replaced band and all seals.
Trans is in 98 Astro 2wd(Moms van)
Drove good for 30ish miles. Trans overheated blew out about a quart of fluid.
She told me
2nd gear was slipping.
4th gear it was hard to maintain speed.
I drove it 1st was fine, reverse was fine, it reved a little high in first hit second and grinded.
I pulled it back apart and band is worn out. Black and friction material is down to metal in 2 spots and cracked.
I do not know why band wore out.
I applied air pressure 30psi to where fluid goes into servo on 2nd and 4th exhaust is not plugged and servo extended and retracted through both holes.
5 of the check balls are in correct spot. 2 fell when removing valve body.
No pinched wire on solenoids.
I am looking for advice or a flow chart on diagnosing why the band wore out.
I can provide more info/pictures if needed. I have GM book on rebuilding trans.
Thanks
SS
Pressure solenoid.
She told me
Thanks
SS
