pjposton said:
I recently rebuilt a 4l60e trans for my 99 tahoe.. it was slipping in 3rd and 4th. The rebuild when very well and installed new TC also. Filled it with fluid and started the vehicle. Problem is that it does not operate in any gear...not even in "limp mode".. with the vehicle running the fluid level went down as it should. I assumed it was the TC... so i removed the tranny to find that the TC was completely emply. I specifically remember adding fluid to the TC so now im in question of maybe the pump went out all of a sudden. any helpful info will be appreciated.. thanks
i read here that you say you filled the trans and then started it. did you add any more to it after you started it? how much fluid did you put in total? these will hold an average of 11 1/2-13 qts total fluid from a empty trans and converter and cooler lines.
if you had that much fluid in it, i dont see how you didnt have a big puddle under your tahoe from the lack of the pump not working, and the converter not having any fluid in it.
*edit* is this tahoe 4x4/AWD? if so, did you change out the input seals on the t-case? in over 90% of these that i r&r, the input seals are hard as a rock, and the t-case overfull. good thing to do while its out.
